WANTED: 5spd Trany swap parts needed
ewittiner
Getting ready to replace my auto with a 5spd, anyone have any of this stuff they want to get rid of free or cheap? Miles on the trany not to big of a deal I will be rebuilding it (should still be working though)Located in or near Portland, OR.Thanks.
-5 speed transmission-5 speed transmission crossmember-5 speed Drive Shaft-Flywheel-Clutch and pressure plate-Clutch Master Cylinder-Clutch Slave Cylinder-Clutch Pedal-Brake Pedal-Clutch hard line
1991S13
Car: '91 240sx Coupe, '00 QX4 4x4, '02 Sentra Spec V
Have you tried posting in the classified section? You will most likely get more hits there.
It would probably be cheaper (and easier) for you to find a local salvage yard with everything. Even if it is an hour or two away, you will probably save a couple bucks from shipping.
