kouki_hmongster »
https://forums.nicoclub.com/kouki-hmongster-u99620.html
Thu Aug 21, 2008 9:49 pm
Man this have been covered sooo many times. you should search first and read the stickies.
what the heck i am bored
jgs log manifold w/ downpipe kit. get something like a gt3071r, and boost away(theres more to it). honeslty its going to cost over your budget, unless you get lucky and buy everything used.
the stock internals can support a lot of power(400whp+) but i recommend you get some engine work if you want a super reliable motor and of course w/ badA$$ ecu tune. you looking at somewhere about 3k to get the motor almost fully built, thats if you take the motor out yourself and take it to the shop.
i say depending on the condition of the motor(compression) if its good then boost it and if it breaks then build the motor. this is to get an idea of how the turbo set-up goes.
