shockload »
https://forums.nicoclub.com/shockload-u28825.html
Sun May 29, 2005 12:42 pm
i hooked up my s-afc2 on my sohc ka-t and set it up but it ran really bad, unhooked it and the car runs pretty smooth but still needs some fuel taken out. when i first set it up i had hot wire ,arrow up yellow to ecu , white to engine bay. set on 4 cyl, i went by the setup in the book for this unit so i dont see where i made a mistake. when the afc is wired correctly and set up it should run like it were off the stock ecu untill you start pulling fuel right? anyways any input would help i would like to have it tuned by this weekend, thanks a lot.
