First you'll need a Synapse FPR. Once you open it up you'll notice the bolts they supply are to big for the fuel rail bolt holes. In order to make this work, go to your local hardware store and buy to allen bolts the same length as the ones that came with the regulator but that will screw into the fuel rail. After that you'll need to grab plastic flanged bushings. I found a size that happened to be the right size to make up the distance for the small bolt. After that you can bolt it in.
I'll snap some pictures of what I bought and did tomorrow.
EDIT: Generic picture of the plastic flanged bushings.
