I felt the same way after it happened to me.spooled240 wrote:about the struts blowing, that shouldn't happen since these manufacturers for these lowering springs claim that they will work for the stock struts because the spring rate is decreased...that's BS if they blow after 6 months.
7-10hrs???? Holy sh*t man!! You need some guidance. That job should take you no more than 3 hours for a newb.GO240 wrote:Either way you look at it its going to take you about 7 hours with new shocks i believe it took 10 hours (minus a few for breaks) to put in my s tech springs and make sure you get the right strut compressor go to orielys autozone is stupid about those kinda things but yeah what every one else said its not hard just time consuming
