MeanGreenS13 »
https://forums.nicoclub.com/meangreens13-u31833.html
Fri Aug 11, 2006 4:07 am
Hey guys just like th etitle says, im trying to find this out. I am about to buy a motorset and when it gets here i plan to put Tomei 1.2mm head gasket, ARP Head bolts, re ring the stock pistons, put all new rod and main bearings in and put all new seals and gaskets. Also going to put a new Power Enterprises Timing belt along with new timing belt tensioner kit. Im probably going to put a T3T4 on the engine when i get my current SR20DET sold, as well as some 600cc injectors and an enthalpy tune, but i wanted to find out if i can do 350-400whp safely on the stock internals. down the road i will be doing cams and valve springs as well but thats as time allows. i just want to get that ****ty stock turbo off the motor.
Thanks for all and any help!
Phil
