want to have a rev limit!!
SR20Drif
Car: 1992 Nissan 240sx
My SR doesnt have a rev limit.... How do i go about getting one?????I REEEEALLY dont want to blow my motor...
dj_lennon_franz
Car: 1992 240sx
sounds like yer ECU has been chipped...mine kicks in DEAD AT 7600rpms...outside of getting yer ecu chipped back...go get some rocker arm stoppers NOW and install those bad boys...dont wanna float a rocker arm by accident
Calum Day
Car: '92 Nissan 240sx
Umm, how about not bouncing off your redline? That might help.
SR20Drif
what do rocker arm stoppers do exactly??? Will they let me rev up high as hell?? What will they let me rev to?
dj_lennon_franz
Car: 1992 240sx
rocker arm stoppers prevent your rocker arms from basically FLYING OFF from revving the piss outta yer car...people in the drifting world use these ALOT because we rev the **** out of our cars
i do not recommend revving your motor over 7500 rpms PERIOD...you have a stock head and stock head gasget...over revving your engine will cause pretty bad damage to yer head...especially in yer sitaution where you dont have a rev limiter...the SR wasnt made for ultra high revving...the CA is a different story in that respect because its a different block and TOTALLY different head design...but yah...id just suggest you purchase some rocker arm stoppers for the sake of ENGINE SAFETY...since you dont have the rev limiter on there you run a HIGH risk of accidentally over revving yer motor and floating a rocker arm
SR20Drif
Cool. Ill get one and have them installed rite away. But i still want a rev limiter.
ItzGenX
Car: Smoke Purple 95' S14.5. Powered by the "Iron Man".
Buy a stock SR ecu that isn't chipped. Then you should have a redline.
terribleto4e
Car: 1992 q45, 1991 fully built mr2 drag car
ECU is not always the case....did you do the swap???
I am not sure which wire it is...but my car had 5 busted wires when i got my car...and i could rev 8+k rpms and had no speed limit....i fixed those wires and now have speed limit and rev limit....2 wires were busted off the harness with the little connector by the batter and 3 were busted off the harness with big connector....but the kid had all the harness's running though the fender where the car was hitting them
fixed all that
david
240SXer
Car: 1995 240sx SE (2jz powered)
I go 7700 on the stock head with a tuned ECU
