New to the club,
Previous owner of a Nissan versa and now an owner of a Nissan Altima 2008 Coupe that i'm completely in love with. I really want to do some mods but my automotive skills are slimmmmmm
Introduce me to the basics!
Thanks!
-Marci
Just spend some time looking through the threads here and you'll get some ideas. I'm in Tampa, FL tooMarcim21 wrote:I also posted this in general forum but figured it was more appropriate here!
New to the club,
Previous owner of a Nissan versa and now an owner of a Nissan Altima 2008 Coupe that i'm completely in love with. I really want to do some mods but my automotive skills are slimmmmmmso if anyone lives in Florida Tampa area or just suggestions in general.
Thanks!
-Marci
I have a 2013 coupe as well, just got it about 6 months ago. You can double check to verify, but I'm pretty sure you should be pre-wired for fog lights. I checked mine a couple weeks ago and the wires/plugs are there waiting. I'm just now starting to do some light modifications and therefore fairly new to it. I plan on doing the fog lights at some point when I can afford them, but recently installed Kensun 5k HID kit. I'm pretty happy with it but I need to do some testing and possibly headlight alignment before I'm fully satisfied with it. I also purchased a footwell led kit and some leds to replace inside the car which gives it a new look.Adriant1 wrote: I'm also looking for mods to add to my Coupe but mine is a 2013. Firstly, I want to install fog lights and make my headlights 8000k (Same 8000k fog lights)
Im afraid to order something on amazon or wherever and find out that I didn't order the correct thing.
So far i've found some parts but i cant post URLs :/
MarkFL wrote:I have a 2013 coupe as well, just got it about 6 months ago. You can double check to verify, but I'm pretty sure you should be pre-wired for fog lights. I checked mine a couple weeks ago and the wires/plugs are there waiting. I'm just now starting to do some light modifications and therefore fairly new to it. I plan on doing the fog lights at some point when I can afford them, but recently installed Kensun 5k HID kit. I'm pretty happy with it but I need to do some testing and possibly headlight alignment before I'm fully satisfied with it. I also purchased a footwell led kit and some leds to replace inside the car which gives it a new look.Adriant1 wrote: I'm also looking for mods to add to my Coupe but mine is a 2013. Firstly, I want to install fog lights and make my headlights 8000k (Same 8000k fog lights)
One of the things I'd like to do that I haven't search/researched about yet is, adding my own vanity mirror lights. Mine didn't come with lights there already so I'm going to look into adding them.
I did remove the plastic panel to look around but I don't see anything that connects into the switch the came with the kitcentralcoaster33 wrote:Well, maybe you can reach up around and behind those switches. Maybe you can just take of some parts of the interior panels to access the inside of the dash. I'm not sure, because I don't have an Altima. You may have to pull the dash.
Here's a link to your FSM:
http://www.nicoclub.com/FSM/Altima/2008/
In there are links to each chapter. Chapter FWD is the foreward and has a table of contents. Chapter IP is instrument panel and has the dashboard and associated stuff described. Look in there for removal instruction with pictures staring at page 10.
