you're not going to break 300 with a DE, unless you do a full high compression build with ITB's or some crazy ish like that. The biggest performance boost after a plenum spacer and HFC or test pipes is going to be an Uprev ECU tune, the electronic throttle doesn't open fully from the factory, so just by syncing this you'll pick up quite a bit of responsiveness. Good friend of mine got dyno tuned, 2005 G35 bone stock and picked up 19whp and 24 rwtq... If you have any specific questions feel free to PM me, my buddy oowns a protuner shop and I can get hookups on this stuff
