Anthonysflying wrote:I had the long tube Nismo CAI. I had to remove the bumper to get that piece out, not to mention it was stuffed in there and always got dirty from the vents in the wheel well. I have a DE though so the piping/bodywork may be different.
EDIT: the only time you need a spare tire...is when you need a spare tire
I have the same intake. I just took it off a couple of weeks ago because it's been raining more here in cali. Our freeways over here aren't designed for heavy rain, therefore lack adequate storm drains. When it rains significantly, there are puddles of water everywhere, making CAI's vulnerable to sucking up water. The DE's nismo cone sits right next to the vents in the wheel well. That area gets soaked in the rain. So I take it off during rain season and put it back on during the spring/summer. Yes, it came with a bypass valve. I'd rather be safe than sorry. Hydrolock is not covered by my warranty (they can link it with CAI installation).
There is a easier alternative to taking the whole bumper off. With everthing unbolted and clamps loose: 1) Jack the car up (front side only). 2) Turn the wheel max clockwise. Remove plastic liner from inside the wheel well. 3) Turn the cone so that it's width fits the clearance between the tire and the front bumper/fender and rest should slide right out.
Another one that i haven't tried yet (which also seems a lot easier) is to jack the car up, remove the plastic cover from under the bumper (driver side, where the lower half of the intake is located) and (theoretically) the cone and bottom assembly should just drop right down.
