Well now you can have it, and now your hidden switch can be wireless!
I installed a keyless entry into my brother's accord using a remote relay off eBay and a Single Pole Single Throw relay I grabbed from the junk yard. I thought the wiring diagram of how I did it could be useful, so I made one to post on here.
Do not cut or disconnect the 'unlock' wire on the lock switch or you won't be able to use the switch anymore, just strip some insulation off them and connect the wires!
NOTE: Here's the catch, just remember to hit the 'OFF' button on the remote after the door is open, because if you don't, the switch will stay on. It won't hurt anything, but it would be like holding the lock switch up with your finger. This only applies to momentary switches, like door locks or auto windows.
Remember all the discussions about installing a hidden switch that cuts the fuel pump off for security? Instead of wiring terminals #30 and #87 to the lock switch as shown, cut the fuel pump wire and connect the ends to these terminals. Keep the remote hidden or on your keyring.
You can apply this to just about anything that operates on a wire lol, it doesn't matter if it's a ground wire (lock switch) or a +12v wire (fuel pump).
remote relay:
http://cgi.ebay.com/12V-DC-REM...1eb47
How relays work:
http://www.explainthatstuff.com/howrelayswork.html http://www.youtube.com/watch?v=wz4X5umfNkQ
Modified by Crunkrich at 9:30 PM 3/9/2010
Modified by Crunkrich at 9:59 PM 3/9/2010
