slownslurious »
https://forums.nicoclub.com/slownslurious-u29303.html
Sat Jul 22, 2006 7:36 am
it would be a whole lot of work... does yours even have the bulkhead fittings that the underhood lines connect to at the firewall? If yours doesn't even have the AC on button than you are looking at installing the compressor, bracket, belt, condensor, evaporator, probably have to replace the whole under dash unit since yours may not have the equipment, and then all the underhood lines. and the wiring harness, I'd guess the wires are there in the harness but it may be like power mirrors in the verts and there is no wiring harness...I dunno man you are talking about a whole lot of work............and in a convertible....
