DCaff300ZX »
https://forums.nicoclub.com/dcaff300zx-u136230.html
Thu Jun 11, 2015 8:35 pm
Welcome!
Some good reading while you save $ can be had in the stickies at the top of the page, which cover pretty much the basics of the Z32 including modifications and maintenance and goes into some detail for many things you mentioned.
Maintenance and upkeep are very important to the car, and lapses in certain areas combined with the age of the vehicle often combine for premature engine issues that some decide are not worth repair and they replace the engine, while others suffer from people who do not understand the engine and car well and modify it incorrectly, or simply beat it to death due to a relative cheaper cost than many sports cars of it's capabilities. The car is hard to work on compared to many cars and the parts expensive, service work also is expensive due to the complexity of the motor and some non-friendly architecture (intake plenum).
The most notorious areas of concern are the electrical connectors, and cooling issues from waterpump failure or more often people who use electric fans and do not replace the OEM fan clutch. Other concerns are the turbos that can go bad due to age and carrier bushing failures as well as seal failures. They also have vacuum issues at times as well as idle conditions, which usually all stem from connector corrosion and poor/needed maintenance.
You WILL need to have a Z32 mechanic available to you, as most other shops will screw up your car and bank account and that includes Nissan. Use them only for OEM parts, and even then if possible buy OEM online from one of our vendors here or someone else.
PLENTY more to learn for you, which can be done reading the build threads, daily posts, and in the tech section!
Good Luck!
