Want 500 HP on FWD Block
Discuss topics related to the VQ series engine.
VQMaxima
Car: 2003 Nissan Maxima and 2009 Nissan Murano SL AWD
Looking for 500 Hp Just curious if this would work.
I may run meth as well, if there is no possibly way to get a E-85 Map. I have also looked into the Haltech as well, Just need to get PNP harness that will plug into the Maxima's ecu.
If anyone has any ideas please feel free to post them. I plan on running a Turbo and probably wanna run at least 12 PSI maybe more. I heard the bottom end should be fine.
Wiesco Pistons 8:8:1Tomei RodsCostworth BearingsJWT S1 Cams and Valves or I could go with the GTM Turbo Cams.
I have though about Heads but I am not sure yet. I plan to Run at least 16-17 PSI on the turbo I am considering getting. The problem is alot of Maxima guys have trouble getting traction, so suspension work will be needed. Hopefully Tein Coilovers and what not will help that along with sway bars and endlinks etc.
Ill probably end up getting slicks as well. If you don't agree with the suspension please feel free to post what you think would be best to get the maximum traction out of this car.
audtatious
With 500hp+ you will need slicks and still lack traction. Make sure you build the hell outta the transmission too. I assume you will be building your own headers and y-pipe or does someone finally make a kit for the 5.5gen maxi?
RioD007
talk about torque steer
Return to “VQ30DE / VQ35DE / VQ35HR Forum”
