Want 265torq as in auto 3.5..? also FS wheels/tires
vq35
Car: 2001 path se manual
Question - body redone, rust obliterated, rear susp redone, NOW everything is boring and I am twitchin for some STREET action (dont go past cottage, sorry folks) plus more power. Mine is a stick 3.5 = 240 ft of torq - I want POWER VALVES (yes yes locktite) and from what I have gathered, the opening/closing function is electronically controlled by the god damn AUTOMATIC transmission. So would there be a way is the question .........to convert it to manual operation for example - I mean it is the same engine otherwise - has this been done/attempted ........ or is it theoretically possible and how ???? Please refrain from telling me that anything is possible provided I have the loot! I understand this clearly and do NOT have unlimited funds so I want to get a used engine and do it meself :ohno: . I have an intake and cat back exhaust and there is a hot cam at 4X4 for $1200 (which happens to be the cost of a used 3.5 .....INSTALLED) Anyway, help would be appreciated - as a newby, I posed this question a year or 2 ago and maybe I didnt pose it properly, but I have a feeling that this is possible, somebody please confirm that I can install power valves....... :squint:
please do not respond to the following if not interested .... Thank you :nono:
Next is items I no longer want/need
1 4X16 inch stock wheels with no tires (plus DIY paint materials - sandpaper, flat black, primer etc) with NO issues $300 FINAL
2 4+1 16 inch stock rims (all with Michelin tires) and 4 tires at 40-50% plus steel spare with tire at 60% tread $400 FINAL
3 4 Bridgestone Blizzak tires at 75-80% tread remaining (awesome IMHO!!!) WITH RUST FREE steel wheels in silver $500 FINAL
OR
everything for $1100 FINAL
LOCAL PICK UP IN TORONTO (CENTRAL) OR reasonable alternative
ARKQX33V6
Just the tires! No rims interested PM me
vq35
UPDATE ON SALE ITEMS
OE RIMS ONLY SOLD
OE RIMS / TIRES SOLD
REMAINING
STEEL WHEELS AND BLIZZAK TIRES - now asking $600 as package only - thank you!
Chuck Tribolet
Car: '01 Nissan Pathfinder
'87 Chevy Corvette
'01 Toyota Camry daily driver
'98 Boston Whaler Montauk
There's a reason the '01 manuals had more HP and less torque: the transmission is marginal for that engine.
vq35
Hey, you know what, I actually read that somewhere a while back but at the time I was more concerned with the maxima my MAF issue as well as exhaust/heat shield noise etc - so I was not concerned with extra power. As soon as I read the post, it took me back to that nagging sensation I felt throughout my little quest for power - now I understand it, I think this would be pretty much the same as for the 3.3/marginally better??!! .....thanks Chuck
So ....... any transmission upgrades out there that have been tried/tested with good results? I have just completed my rear wobble issue (got stock and will use the old arms/panhard rod to updrade with 4x4 bushings - 8 total......wanna drive it into oblivion god willing) so the point is now the front is coming into play = strut/stock mts, lower arm bushings, and while I am there, thinking of a shift linkage rebuild, upgraded clutch, sealed, warn hubs, and top it off with this LSD upgrade I was reading about on the 'other' pathfinder site ....... any info appreciated folks and thank you
