DroptopDrifting »
https://forums.nicoclub.com/droptopdrifting-u46660.html
Thu Feb 19, 2009 3:33 pm
"This is not entirely true. Mufflers quiet your exhaust sound through vibration reduction/resonation and also through airflow restriction. Removing your muffler can result in small performance gains by contributing (albeit very little) to weight reduction and less exhaust restriction.
Secondly, the point of a resonator is not to make your exhaust sound deeper. A resonator has a few effects. 1, it causes destructive interference of some sound waves to reduce overall exhaust noise; 2, it changes the resonant frequency of the exhaust system thereby changing the exhaust tone; 3, it can be tuned to aid in exhaust flow out from the engine."
mrodrig2: a "turbo" muffler, or most of which you find on ebay, basically any muffler unless otherwise noted, has no chambers. all it does is just change the frequency of the noise and look nice. a stock muffler, or if you buy one, has one or two chambers depending, and the chambers reduce gas flow, therefore adding backpressure and reducing possible hp gain. there is no airflow restriction in an open muffler.
yes, the resonator reduces noise a little, but for the most part just "changes the resonant frequency". your words just backed up mine. and the tone it tends to change to is a deeper tone. which is what i said. and no, they cant be tuned to aid in the exhaust flow, because if you take out the little balls inside them, it no longer "resonates" it just acts as a test pipe. like a "gutted cat". in a gutted cat situation, the cat is wiped clean of its inside chambers and it also acts as a test pipe. it no longer reduces emissions.
