Wanna see what I did to my car???
ceefromdasco
Car: chuki RMS13
What it do NICO members? I am fairly new to this, but since i couldnt have done it without NICO i gotta post some pics, someone wanted a write up to so heres my attempt......
This is her, bone stock except for the K&N filter and B&M short shifter......
Then i recieved some of these. Stance GR + pro from Mach III in Frisco, CA
I the took them apart to install the supplied 9/7 springs and I put some of this on the thread because I like copper, and it looks hot!
this is what they look like after you rub it on...
After they were all prepared I lifted my car up to install them, they are pretty straight forward, Im sure theres tons of threads on how to install them. I also think you can see the small difference my light shading did to the parking lamps.........
This is how i shaded my parking lamps. I first took them off by loosing up two screws......
Then I had to disconnect the harness....
I then heated the edge where the lens is attached to the housing and just slightly warmed it up, not too much cause you'll discolor the plastic.
Once it was warm enough, i just carefully pulled the lens off the housing, I wiped the inside of the housing with some alcohol, and sprayed the inside black, the first one I did, i taped off the groove where the glue is, but you should just paint the whole thing, otherwise your edge will look lighter than the rest off the lens, the second one i did came out way better!!
While I had the lens off I decided to polish them up a little, now I know these are all chipped, but i was just testing this on these, I'll shade some new ones later.
I first pulled out my dads weak *** buffer, and rubbed some of this on the terry cloth path the buffer already had.
You can get that at your Kragen or whatever parts store you go to (They all SUCK!!!) Anyways I just left the buffer on the floor holding the switch and handle with one hand, and held the lens with the other and just rubbed til I was happy...haha
After your flat black paint dries, you can warm the glue in the housing again and attach the lens back in place, make sure you push it in all the way until the clips click in. Attach the harness, screw them in and Voila, shaded parking lamps for free! (I had everything already)
I also recieved my lip and skirts so they went on too, temp. only.
my Stances are great! they can go way lower too. This was how it looked lower, and it can still get lower too......
Oh yea, I forgot to mention that I did wash my car and rubbed some claybar on it too.......
So now im totally happy with my front end, next I want to get some rims and suspension stuff. I was gonna get an SR cause my KA has a bad rod bearing, but now that I saw my car like this I wanna save that money, get a new KA and do other things to it. SR could wait, feel me?
FSUDrifter
Car: trying to decide on one...
Looks sweet. I bet your rear tires are loving that negative camber.
boznuttz
Car: MS13
looks great, how much did you pay all together for the stance?
WI_S14_Goldie
Car: 1995 Nissan 240sx SE, 91 240 fastback LE, 1997 kouki S14, DD = 93 Nissan Maxima
yeah that was way too low the (second picture). How much did u purchase the stance coilovers for?
ceefromdasco
Car: chuki RMS13
I wanna get some rear upper arms from SPL any word on them? I got my Stance for $1280 out the door. Thanks for da comments
hannibal
Car: Red Line to Glenmont
SPL has a great rep on this board, but I personally have never used their products. Ive heard their RUCAs are rebadged Cusco's.
Your car looks great on those Stances! And I gotta add: I'm digging your house/neighborhood in the background. Ive only been to SF once as a kid, but that area seems so familiar.
lbrowne
Anyone else chuckle when they read "bone stock except for ...."
This is not intended to flame at all, I just find it humorous
edit: nice car btw
moyea
Car: Paddle Shifted 92 240SX SR20DET, 02 Frontier S/C, 90 240sx ITA
Dang, you got that thing dropped! Be careful with lowering your car in SF, I could tell you some stories.
Where did you get that lip? Is it functional? I've been looking for a functional splitter myself.
SeVa-S13
Car: '05 GTO 6spd
Car's lookin' good.
Oh, and nice bowl.
CBCUSTOMS
Whats even funnier then that is the bowl and the beer in the background
sillyverts13
SeVa-S13 wrote:Car's lookin' good.
Oh, and nice bowl.
+1 on the corona and pipe.
Have you played with the dampning on the 9/7's yet? Like you, I put the stiffer springs on my stance right out of the box. I set the fronts to 15 and the rear to 8. The front seems a bit bouncy but handles spectacular. I would suggest getting Rear upper controll arms and rear toe arms asap. Your tires will love you. My first reccomendation would be battle versions (a lil biast perhaps) but you couldnt go wrong with cusco or spl.
whiterps13
Car: white LE hatch
SPL stuff is awesome. Ive got thier RUCA's and Ive had no problems.
Thats a tobacco pipe, right?
94_240sx
Car: 94_240SX
ceefromdasco wrote:I wanna get some rear upper arms from SPL any word on them? I got my Stance for $1280 out the door. Thanks for da comments
Don't think twice. Get SPL RUCAs. I have Stance GR+ Pro and SPL RUCAs.
ceefromdasco
Car: chuki RMS13
haha, nuthin like a little bomb and beer to get my creative juices flowing... No i havent played with the dampening yet, or even drived it to long. My KA has a bad rod bearing so it sounds like $hit. I will definetly get my rear suspension components first, i hate that negative camber look. I read a thread somewhere where they posted thier comments on different damper settings and it was really good, i havent had time to find it again though, i think its on ziptied.net or something. damn, my car needs something in the back huh, maybe that pdm rear bumper cover and a CF wangan tail from raceonusa.com will do.
nismofly
Car: 89 Nissan 240SX Hatch
SPL makes awesome stuff, you should get your tie and tension rods and everything else there too
IWannaS15 wrote:SPL has a great rep on this board, but I personally have never used their products. Ive heard their RUCAs are rebadged Cusco's.
i think he copied the design of the cusco's because he felt they were the best and couldnt be improved...
Pho King
Car: Red hatchback.
You should take off those grills, and paint them black again, haha.
94_240sx
Car: 94_240SX
Quick question for you guys. I saw ceefromdasco used heat gun to take off the lens. Will tail light lenses come out like that too?
Tulsa_S-13
Car: 1991 SR 240sx
No offense, but why do people insist on buying coilovers and than adjusting their suspension wayyyyyyy to low? This completely changes your suspension geometry and results in a car that actually handles worse!
If your going to get coilovers spend the time to get them adjusted properly......
Oh and get some adjustable RUCAs while your at it.
nissan_blood
Car: Striped s14
Damn hes got the same KB pipe I do this is wierd. Looks nice and the pipe is a Billy got the same one.
da40
Car: 1995 SE 240sx
lookin good man!!
jaylivesinsf
Car: '92 Nissan 240sx Hatch
Your car is pretty low but looks very clean. I like the lip a lot. But damn...are you gonna be driving around the city often because you have to be VERY alert of the damn potholes here. It's good to see local 240's on here!
boj240
Car: 93 hatch sr
YESssss ur the best thx for the write up ... will do soon will post pics when i do
~4N~
Can the Loctite Anti-Seize Stick be bought in auto parts stores?
BLACKHILLS13
Car: 92 S13 HATCH
I think your car looks pretty good, and I like where your mind's at about suspension first, horsepower later. I'd raise the height a tad, to where you don't leave that lip on a speed bump somewhere. LSD next? That would compliment your new handling nicely. Also, a good pillow ball tie rod end and new tensioning rod will handle the car's new ride height better.
P.S: it might not be safe working on your car while under the influence of cool ranch doritos?
MeanGreenS13
Car: 2011 Chevrolet Silverado 2500HD
holy speedumps batman! better be careful that low especially seeing as it seems you live in a hilly area lol
Axel Grungy
Car: 2001 G20 5spd
for god sakes raise that thing, thats stupiiid low. youll get road rash on your *** (kinda rhymes)
Ferrari_extremist
Car: 1993 240SX SE coupe
Looks Like it's off to a really nice start.
240on430
Car: 1993 240SX SE
Nice start with stances.
I'll be on the lookout for your car... I'll blink my lights when I see you around SF or something.
Can I have your stock suspension?
Black on Gold
What lip is that anyway? I like it
ceefromdasco
Car: chuki RMS13
Tulsa_S-13 wrote:No offense, but why do people insist on buying coilovers and than adjusting their suspension wayyyyyyy to low? This completely changes your suspension geometry and results in a car that actually handles worse!
Well thanks for the comments guys, its hard to find a group of guys that know what they talking about, well I dont know how available the sticks are, i bought a set at the commercial counter @ Kragen, it retails for like $50, but I used to work there so guess how much it cost me, haha.
And Tulsa, dont get so worked up about low cars, how do you know that my car handles worst? people buy coilovers for different reasons, wether it be to slam thier cars or to "improve handling" thats their desicion. And I got a question for you, why are there so many people that think they are suspension geometry engineers, or these know it all racers, that think every mod should be for race purpose only. I mean I know alot of $hit about cars, and I dont go around asking how much horsepower does that sticker give your car? I bought my coilovers for one reason, adjustability. When im driving around town to and from work, I wanna look cool.( Not that my car is cool yet) and if I ever decide to go autox and can easily change it up.
