Blackmobile »
https://forums.nicoclub.com/blackmobile-u106210.html
Tue Apr 14, 2009 10:34 am
i have to say i love neons and underbody lights. but everyone tells me they're tacky but i like them nonetheless. if you want to wire them up without seeing them as you open the door, run the wires into the engine bay and then wire them through the firewall into the front and you can install a switch into an empty slot where the VDC and TCS are (if you have them).
look in the DIY section to see how people wire the audi led strip wires through the firewall and do the same process.
and no, you don't have to hook them up directly to the battery for them to work, you can tap into an alternate power source, by either splicing the wires or using wire taps.
