I'm not convinced it was the gas that caused a catalytic converter failure?I checked the warranty booklet on my 06 and it states that the converter is covered for 8 years and 80000 miles. I also purchased an extended warranty from the dealer for an additional 4 years and I'm covered until 97000 miles & or till 2012.bublightyear wrote:guys beware of wal-mart gas it may not be the octane it says.
Ok, so I was out of town and had to stop at wally world and thought I would save myself a trip and just get gas there. To my surprise all gas was priced the same so I figured that some DS just keyed in the price wrong when the price changed. At the time I was pretty excited to get premium at 20 cents less per gal. Half a tank later get SES w/ code P0430.
My stealership says that the bad gas killed my cat.contverter...60k...not under warranty. Just really sucks!!!!
back in the mid-80's my Dodge POS would shut off while turning at low speeds. Talked to the Dodge service dept and they asked what gas I was using. Was using Crown gas. They told me to use a brand name gas such as Exxon or Amoco and my problems would go away. Evidently, their cheaper crappy gas had some component that was clogging my injectors. Switched to Amoco (BP) and haven't had the problem in over 20 years.Oh, and last time I checked there were people still bying Crown gas. There will always be some people willing to go the cheap route.But, you get what you pay for! Not trying to change your ways at your age Telcoman!!! Plus, sounds like you have been lucky with your gas anyway!Heck, I recently ran 87 octane in my SEDAN cause that's all I could find! BUT, it's a name brand. However, my COUPE would stay parked before I put 87 in it!!!telcoman wrote:
No gasoline station is going to remain in business very long if they are selling inferior or dirty gasoline.
Wal-Mart gas is apparently crap I very rarely venture away from my v power. I am surprised though that it is that bad I wonder what the contributing factor to the Catalyst effeciency code is though.bublightyear wrote:guys beware of wal-mart gas it may not be the octane it says.
EPA Website Warranty SiteUS Government wrote: A. PERFORMANCE WARRANTY
The Performance Warranty covers repairs which are required duringthe first 2 years or 24,000 miles of vehicle use because the vehiclefailed an emission test. Specified major emission control componentsare covered for the first 8 years or 80,000 miles. If you are aresident of an area with an Inspection and Maintenance (I/M) programthat meets federal guidelines, you are eligible for this warrantyprotection provided that:
* Your car or light-duty truck fails an approved emissions test; and
* Your vehicle is less than 2 years old and has less than 24,000 miles (up to 8 years/80,000 miles for certain components); and
* Your state or local government requires that you repair the vehicle; and
* The test failure does not result from misuse of the vehicle or a failure to follow the manufacturers' written maintenance instructions; and
* You present the vehicle to a warranty-authorized manufacturer representative, along with evidence of the emission test failure, during the warranty period.
During the first 2 years/24,000 miles, the Performance Warrantycovers any repair or adjustment which is necessary to make yourvehicle pass an approved, locally-required emission test and as longas your vehicle has not exceeded the warranty time or mileagelimitations and has been properly maintained according to themanufacturer's specifications.
Correct me if wrong but didn't NJ have a few dealers of different gas stationshave problems with water in the gas a few months back that caused cars to stall out?telcoman wrote:I can't speak for other states but here in NJ we have mandatory state inspection as required by the EPA. New vehicles do not have to be reinspected for 4 years then every 2 years thereafter including an emissions test.
Gasoline sold at retail stations is tested by state inspecters that lower a test container into the tank. I occasionally see them. Consumer reports, Car Talk and many other sources have frequently stated that the use of regular 87 octane gasoline in most cases will not harm a modern engine. The CPU will adjust the timing and I have never heard a ping even under hard acceleration.Your eighties POS did not have a CPU but you probably could have retarted the timing?
We have a refinery here in NJ and the tanker trucks that fill up the major brands or the independant stations all look the same with no brand names on them. Many times the independants will get what is left in the trucks at a lower price but the gasoline is the same.
When traveling, I usually fill up at busy truck stops such as Petro
Telcoman
Yes, you are correct. I believe that one or two stations on the Garden State Parkway were affected a few months ago and they paid for the repairs of the affected vehicles. They were however major brand stations. I'll try to search & look it up.G37 Man wrote:
I don't know but I was in Florida a couple of weeks ago and filled up the Hyundai rental at a Marathon station with regular.Jacko3 wrote:Telco:
So, if they are all the same, when does big marketers like Chevron add their Techron to the gas before trucking to the gas station?
I highly doubt that one tank of gas killed the car - it's not like they filled your tank up with Sprite!bublightyear wrote:guys beware of wal-mart gas it may not be the octane it says.
Actually, not all gas is created equal. While all crude is the same, refined the same...etc, the gas that you buy at some stations is not the same as others. All gas in the US is regulated by the EPA - this means that you are ok with putting it in your car. However, not all gasolines contain the same amount of detergents that are designed to keep your engine running clean.telcoman wrote:Whether its regular 87 octane, 91 octane or 93 octane, the gasoline is chemically all the same whether it has a brand name attached or not. Marketing and franchise fees adds costs to the product which will account for higher pump prices at major brands such as Shell, Exxon/Mobil, Chevron etc. vs non branded independent stations. Purchasing gasoline under contract vs purchasing on the spot market also accounts for a price difference.Just because the product is a few cents cheaper per gallon at an independent station does not necessarly mean the product is crap.
Ok, so you chimed in why??? working for a oil company/walmart trying to make them look better?BTW I have a friend thats a Ford tech & that dealership has replaced 13 cat.converters this summer that came in with complaints like mine. It may not be Sprite but something is obviously wrong with the gas in this area.marlin29311 wrote:
So while the base of your fuel is the same, the end product is not. If all gas was the same, we would have perfect competition in the fuel market and all prices would be the same too...
I chimed in because otherwise there would be no other ideas floating around and you would all think that the first answer was the right answer. Before you go and start accusing me of stuff look around at my posting history and my profile. If you did, you would see that I work in the insurance industry, and a lot of my recent posts deal with Shell's V-Power, which is the only thing that I put in my car. I hate Wal-mart and everything that they do and refuse to buy anything there.bublightyear wrote:
Maybe Ford sucks at making cars - hence their issues with their CAT converters. O, I'm sorry, did you not want to hear someone talk about this too?
Try actually READING what I said - I noted that not all gas is equal. You buy independent brand gas, you might not be getting the best fuel for your car. I still stand by my comment that one tank of bad gas didn't destroy your CAT. If it only took one tank of slightly bad gas to break something in your car, all my old cars should have died from water in the line already...
