Walk around my car
articzap
Car: 2014 F150 FX4
http://www.youtube.com/watch?v=QZf54yjEqxc
Before you say it, yes my fuel pressure is to high. I'm working with Synapse to get my problem fixed.
1990 Nissan 240SX
-CA18DET-Greddy Turbo Outlet-Apex'i 3" Downpipe-Intense Motorsports Resonator/Test Pipe-Apex'i NOIR 3" Catback-Yonaka FMIC-2.5" IC Piping-Synapse BOV-KA24DE Throttle Body-Walbro 255lh-Synapse FPR-ACT 6 Puck Clutch-Mishimoto Radiator-Defi Blue Racer Boost Gauge-Apex'i SAFC
-Skunk2 Lowering Springs-Adjustable RUCA's-17" Tenzo RS5's-BFGoodrich KDW
Rin5
Car: 1990 240sx CA18DET, 1990 240sx SE fully auto (Daily)
hows that synapse bov? is it good? and why did you choose it? my friend has been telling me to get ssqv or a blitz cuz he likes the whistle it makes...but for some reason the synapse attracts me... :P
articzap
Car: 2014 F150 FX4
Synapse is by far the best BOV. Friends of mine have SSQV's, Tial's and many other brands. Synapse reacts stupid fast. Even if you let of the throttle just a little bit it will "flutter" as it slowly releases boost. There is no compressor surge and no dialing in. Hook up the two vacuum line and it's connected and reacting perfectly. It remains open in vacuum and is held shut by boost. Since its open in vacuum you'll have to recirc but it helps to increase spool time. On the stock T25 there is no lag. I have full boost by like 2000 RPM. It may even be less then that. I would recommend it to anyone and everyone!!!!!
mbmbmb23
Rin5 wrote:hows that synapse bov? is it good? and why did you choose it? my friend has been telling me to get ssqv or a blitz cuz he likes the whistle it makes...but for some reason the synapse attracts me... :P
Here's what I found on an ebay ad:"Fast-acting designFunctions as a blow-off, diverter, or pop-off valveIncludes 1.25" recirculation fittingUS Patent #6,863,260Eliminates the diaphragm with a multi-tier self-centering piston actuatorSignificantly reduces or eliminates compressor surgeWill not leak boostAwarded "Best New Product" at SEMA'08"
That last line (if true) gets me interested....although I will need recirc and not sure if this can easily be made to do that....even tho it says it comes with the fitting. I've been out of the "parts buying" scene for awhile but this is worth checking into.
articzap
Car: 2014 F150 FX4
Look at how i routed my recirc. Silicone hose and some brass fittings.
zmannz
Car: 89 s13 coupe- track car
92 s13 coupe- dd
I have heard rumors from a friend that the synapse design promotes fast wear of the internals, may not last as long other BOV's. But I love using the SSQV with megasquirt.
articzap
Car: 2014 F150 FX4
Quote »Synapse Engineering has redesigned the Blow Off Valve with a piston actuator instead of using the common diaphragm. The equates to fastest response time on the market. The pull type design stays closed under boost and uses synchronic technology to control the release point of the blow off valve. The lack of a diaphragm increases reliability and durabilty, with no need to replace worn internals.[/quote]What you hear I'm pretty sure is just a rumor.
