Walbro on the S14
dan1901
I just bought a Walbro fuel pump, and I was trying to do the install thinking that it would be pretty strait forward(which is what ive read). So I take out the seats, get under the fuel pump cover, get the ring and hoses off and take off the top thinking out would come the fuel pump... Wasn't the case. How do you get the fuel pump out in the S14?
:: orion ::
Car: '96 240SX, with KA-T @ 12psi...
It's attached to a "carrier" that slides onto the front of the fuel tank...from the trunk, reach forward into the tank and you'll feel a metal bracket on the front of the tank.
Grab it...pull up, then out. It'll slide right out.
- Brian
