Walbro in 240sx
sr20detmaybe
Car: 95 240sx
Will it be ok to put a walbro 255lph in my car with everything else fuel related being stock? I just want to go ahead and put the Walbro pump in before I do the SR swap which ill start in a couple of weeks. Thanks.
SlidnSideways
Car: 97 Nissan 240sx SE
My brother did...Ran it for bout 6 months afterwards too.
It still runs but he dropped his fuel tank out to do some welding on the frame because of rust. He wont pass emissions but were not sure if thats walbro related or not...i dont think he passed before it...
--Tim--
sr20detmaybe
Car: 95 240sx
so it should be ok?
:: orion ::
Car: '96 240SX, with KA-T @ 12psi...
As long as your FPR is in OK shape, NOTHING will change.
A lot of people will say their base fuel pressure went up when they installed a Walbro, but that's usually due to a bad or dying FPR.
Basically, it will run just like stock, but have the capacity to flow A LOT more fuel if needed.
- Brian
InsanityInc
:: orion :: wrote:As long as your FPR is in OK shape, NOTHING will change.
- Brian
No, your fuel pressure will go up. End of story. It has nothing to do with a broken FPR. I tried a brand new one on my car, still had high fuel pressure. Put the other fuel pump back in, went down. I run an adjustable FPR now. If the pump is flowing more CFM through the same size opening, you will have more pressure in the rail, it's very simple math.
skatanic28
Car: 96 240sx
my fuel pressure didnt change when i switched to the 255lph, and i've seen the same with a couple others as well.
InsanityInc
skatanic28 wrote:my fuel pressure didnt change when i switched to the 255lph, and i've seen the same with a couple others as well.
Are you sure you're measuring it in the right place?
EDIT: also, are you sure it's actually a 255lph? Walbro does sell ones that have stock flow. What pressure are you reading, anyway?
Modified by InsanityInc at 10:43 PM 6/24/2005
tiger
I luv the little hum they make. I have 2 , 255lph pumps, a brand new HKS one and a older hks one.
