walbro fuel pump...this isn't normal, is it?
slider78
Car: 1990 240sx
when I turn hard, my rb20 almost dies and then comes back...has any one experienced this? even with my tank half. could it be going bad? I will install a fuel pressure gauge as soon as possible.
Shocker
Car: 89 240sxHB rb26/30
pull the sump bracket, it might be loose....
slider78
Car: 1990 240sx
I pulled the pump and inspected it, all looked ok, except for the tank seal, it was very stretched, had to modify it, I'm not sure if the tank was maintaining its pressure. I dont think low tank pressure would cause the car to loose power on hard turns.
neonbomb
My seal was very stretched also, but you just have to jam it in there and twist on the big locking cap. Is your FPR ok?
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
Didn't someone have an issue with only turning right and their car would die?? This sounds very familiar for some reason, but would have been a long time ago.
And gas tank pressure doesn't increase fuel pressure. Well I shouldn't say zero, but a negligible amount. The seal is mainly important for keeping fumes in the tank and EVAP system instead of in your car.
Carl H
sounds like an iac related issue like the ps switch not being wired in or a super low idle.
Joe
Darius wrote:Didn't someone have an issue with only turning right and their car would die?? This sounds very familiar for some reason, but would have been a long time ago.
when my car is low on gas on track it cuts out on long right corners.
its very scary haha "OH GOD ITS BROKEN...oh wait there it goes..i need gas"
slider78
Car: 1990 240sx
I just ordered a fp gauge, so when I put that in I'm going to drive it again and see. I will post back then, thanks for the coments
