Walbro, 370's, SAFC, N/A
mirra32
i know there is a thread somewhere but i can't find it now...neways..
.as stated above....all this will be on a stock motor along with my wideband....I just wanted to make sure i can install the injectors and walbro and not have any problems...i think i saw to run +27% across the board...are there any other settings for the "SAFC I" i have to perform to get it running good, like all that 5 io and out stuff....
just trying to get as much on right now before i go turbo...i have the safc and wideband installed and running fine....
Modified by mirra32 at 3:30 PM 1/10/2006
skatanic28
Car: 96 240sx
you actually want the safc at -27 to rescale for the 370's. once you get it up and running you can make the small changes by referencing your wideband.
i ran for like 6 months like that without a problem, only bad part was really cold starts (< 30* F)
Florida240sx
Yea think for a second.370cc are 100cc more than our stockers so you want to subtract 27%. 27% is an average number that works for most.Don't put it at 27% and ignore it. Check your A/F ratio
mirra32
thanx ya...i just wanted to make sure before i install this stuff..The -27% is just a refrence point to start with....i've been messing and starting to get the hang of the SAFC
so no other changes are needed on the SAFC...
.i'm so close to turbo i can feel the boost...the only part i need is the MANIFOLD>>>>once again thanx....
