Walbro 255
Drifticidal_Rob
Car: 91 240sx
Ok, here's the deal. Im getting ready to button up my ka-t project and was wondering if i absolutely have to upgrade my stock fuel pump? I have 370cc injectors and my ecu has been tuned.
DevilMB3017
You absolutely should.
The more fuel you need out of your tank, the more the pump needs to work. If your pump decides to die at full boost, you're looking at a whole new motor compared to the cost of the fuel pump.
oz240red
Car: 95 T3/T4 KA-T
What he said....
It's not expensive and it's not hard to do. Check the write-up on how to change the pump. It has pictures and all the instructions you'll need.
Drifticidal_Rob
Car: 91 240sx
cool, thanks for the info. Im hoping its gunna be done this sunday, all I have left to do is remove and tap the oil pan, fuel pump, and run the oil lines
DevilMB3017
Drifticidal_Rob wrote:cool, thanks for the info. Im hoping its gunna be done this sunday, all I have left to do is remove and tap the oil pan, fuel pump, and run the oil lines
Some of the hardest parts to go, but good luck man!
Drifticidal_Rob
Car: 91 240sx
thanks, im sure i need it. I got a lot of help so it shouldnt be too bad. I'll post up some pics when its done.
