Walbro 255 lph fuel pump custumize for a Q45???
boonseyQ45a
Car: 1994 Infiniti Q45a
Hello NICO members!!! I am going to do a fuel pump on my Q45 and was wondering if I should stick to the OEM products OR can I go and purchase an aftermarket (Walbro fuel pump) and customize the brackets to make it fit??
thanks,MItchell
qship96
Car: 1996 Infiniti Q45
OEM nissan pump is 250 from http://www.everythinginfiniti.com
Ebay seller "mr. fuel pump" advertises japanese made OEM supplier q45 pump brand new for $145, advertised as direct fit drop in part.
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
Are his fuel pump guaranteed new?
Do you have any experience with them?
qship96
I have no experience with them. He advertises the pumps as brand new.I would contact him to ask any questions if you are interested. Post results if you do!
Raxephon
Car: '04 RX8...for the moment...
You can use a walbro in your Q but you have to retain the rubber boot/sleeve from the original pump for it to fit in the assembly correctly.
Also plan on doing some soldering/heat-shrinking as well.
(And do NOT slack in precautionary measures regarding gasoline and gasoline vapors!)
Good luck.
