AZ89two4Tsx wrote:Be advised, Walbros are notorious for failing unless you run them over a 1/4 of a tank of gas. They cool themselves by being submerged in fuel.
Might be why you've gone through 4 of them Lobo.....
Between 2002-2004 when I got my 1st SR20, they were having a lot of problems with the old Walbro 255lph design. I noticed when I got my up to date one this year, the sock and hole are wider at the bottom allowing the pump to cool better. I hardly ever ran the tank down to 1/4 back then. Yes you are right that was one of the issues people ran into.
Plus I had to modify the metal canister by sanding the lip off where the old rubber piece sat to make the new one fit.
