stevespeed »
https://forums.nicoclub.com/stevespeed-u29997.html
Thu Jul 01, 2010 4:41 pm
I have an RB25DET Series 1 swapped into my S13
Swap has done to it
Greddy intake manifold
Q45 Throttle Body
Front Mount Intercooler
Stock Ecu (no upgrade or retune at all, no SAFC 100% stock)
GreddY RS BOV
Running 8Psi currently sometimes I step it up to 13 but recently put it back to 8
stock intake pipe with the stock MAF
Walbro 225LPH fuel pump
Stock fuel pressure regulator
all stock sensors, no wideband.
pulling 15-16 inchs of vacuum at 800RPM idle
Timing was set at 20 degrees btdc at 650+-50RPMS with a mac digital timing light and the CAS has not moved at all since, timing belt and head are both new.
So whats been happening is that I was driving down the highway one day and the car felt like it lost alot of power, so I took it home and started fiddling with it, after a plug change BCPR7E-8 (i think..), and boost leak tested it to see if that was the problem.
The Boost leak test returned nothing wrong so I started just redoing vacuum lines to make sure that was not the issue either, and took it out for another spin.
First time out the car just felt extremely down on power and sluggish getting to redline. Next drive first felt insanely down on power like the engine was just struggling to breath, and then in 2nd during a WOT pull the car felt like it hit a brick wall and basically just stopped accelerating.
I currently am thinking its either an Ignitor chip or a MAF.
thoughts/ questions about the setup. this has been haunting me for weeks
