WACK... squeekin and more squeekin
All things Altima Coupe.
theoctopussi
Car: 2008 Altima Coupe 2.5 6MT
alright, so I noticed this mornin that somethin is squeekin under the hood, I think it's the fan belt.... anyone have, or had, this problem? is WD-40 good enough?
AND, my brakes are squeekin too... any solutions? caliper grease?
Thanks!
stsxcrle
WD-40 IS NOT A LUBE!!!!! it's more of a degreaser than anything else.
/rant
theoctopussi
LOL i know... so do you have any suggestions? 3 in 1 lube?
theoctopussi
not everyone at once now... can't flood the thread with so many posts.
stsxcrle
Sorry man, I exhausted the extent of my mechanical knowledge on the last post.
theoctopussi
LMFAO!!! good sh*t haha
GryStrm
Car: 2008 Altima Coupe 3.5
a/c belt?...is that squeeking?
Scandinavian Flick
Car: 2008 Nissan Altima Coupe 3.5SE
for the fan belt its not a matter of lube, you really dont want lube on a belt, they used to make a belt dressing that would remove grease and condition the rubber, not sure if they make it anymore though, usually the squeaking is caused by either a liquid, like radiator coolant, getting on the belt or something of that nature that would severely dry out the belt,it could also be loose, but i doubt that. so what i would do is just replace the belt. as for the brakes assuming your brakes pads arent just worn out which would require replacement, you may have just hardened the pad surface, which if you take the caliper off and just take some mild sand paper and sand on the pads surface you can remove the hardened spots, and your brakes should quit sqeaking
theoctopussi
could be the a/c belt... I have that thing on constantly
theoctopussi
THANKS! I appreciate the advice... I'll take a look at the brakes and pinpoint that squeek under the hood... thanks again!
altimacoupelvr
Car: 2008 Nissan Altima Coupe 2.5S Code Red/ Blonde Interior w/ Convenience Pkg.
i have the squeaky brakes too!!! and i know it isn't worn out...shouldn't be anyways. i don't slam on my brakes or anything!
