170,000GBP and it can't be driven on the road. Still, might actually be worth the ticket just to see the looks on other drivers' faces...
Doubtful. With the "two" rear tires linked together (one super-wide slick), unless there's some uber-trick suspension in the rear (which I don't see any evidence of) to allow the two to move independently, it appears to steer just like the Can-Am. You're not gonna camber those steamrollers in a turn, so I don't see it cornering meaningfully.MinisterofDOOM wrote:...and you can't shift your weight around.
But the W8 weighs twice what a Can Am Roadster does, and gets non-DOT race slicks...so maybe it has a chance at going not straight a little bit aggressively.
Methinks someone at that company isn't very bright, because "power" has nothing to do with legality. I'm sure it'd be quite simple to certify as a motorcycle.MinisterofDOOM wrote:Manufacturers Lazareth say that the Wazuma V8 is so powerful it is purely a track-only vehicle.
