fun240 »
https://forums.nicoclub.com/fun240-u58771.html
Mon May 11, 2009 6:02 am
If it sounds like a V8 when you start it up and has barely any power then its an Injector
If the car does not rev past 2500 rpms, its your MAF. You'll also notice with your MAF out, that the car bogs while driving(cruising).
With an injector, you can tell right away.
Crank the car up with it doing that, unplug each injector 1 at a time, if the car does not make a change in the way its performing when you unplug a certian injector, then its whatever one you unplugged is bad
