Ex-Ca Driver
In laymens terms, the Inlet camshaft is advanced forward so that it gets opened earlier. This is done at 4000 rpm on the Q45. Your 91 model has it.
It basically changes the overall Cam profile to what we call a Lumpy Cam. These cams make the engine work very well at high speeds but give it a poor idle. Just look at a drag car at idle, the car rocks badly & not the result you want in a Luxury Vehicle.
Most run-of-the-mill cars are made to idle nicely & these really don't rev very well, & if you do try to rev them, they don't have any power at revs.
So Nissan, & other manufacturers, designed a system to give us the best of both worlds, Smooth idle & great power at revs.
If you look at the front of the engine at the front of the Inlet cams, you will see a little solenoid poking out of the plastic covers, this is what activates the cam change. It just lets Oil Pressure in which forces the cam around a few degrees, & when the switch is off, the cams return to their nornal position.
Hope this has helped.
