VVT, Not working? How to test it?
Bioxide02
I have a series 1 rb25det motor and I don't think the VVT is working on it.. Is there any way to test it to see if it is working or not?
Modified by Bioxide02 at 7:48 AM 12/16/2005
krayton
what makes you think that?
matt_calgary
Car: 1989 240sx
Bioxide02 wrote:I have a 97 series 1 rb25det motor and I don't think the VVT is working on it.. Is there any way to test it to see if it is working or not?
I didn't know that VVT could get broken!! Its a program made in your ECU, I don't think it breaks or can be tested for being faulty. Maybe your getting knock or your timing is outta wack or both???????
Bioxide02
krayton wrote:what makes you think that?
Because I don't hear it "clicking" at idle/rev up the motor?
Joe
its not vtec. there is no audible clickling.
all VTC does is adjust cam timing, NOTHING like vtec where you would hear an audible changeover. but even vtec does not work at idle.
ive unplugged my VTC and never noticed a difference on track. so i dobut yours is broken.
Bioxide02
Thats wierd.. Because when my friends VVT wasn't working and then it was working.. It was a noticable difference.. I understand it isn't like VtAK.
Joe
well as far as i know there is no audible click when it works, because all it does is rotate the cam to change the timing. so i wouldnt base the fact if its working or not on weather you can hear something at idle.
Bioxide02
Kamin wrote:. so i wouldnt base the fact if its working or not on weather you can hear something at idle.
Can't hear it when accelerating/reving either. Two of my other friends have RB25's as well.. And you can hear the "clicking"..
But, we are getting off-topic here. This thread isn't if VVT makes a differance or not.. The question was.. Is there a way to test the VVT to make sure it is working correctly?
StricNyne
i never heard a thing on 25
TheOne
Car: 93 240sx FB
for a sec there i alwasy though that only the NEO rb25's had VVT or some form of variable valve/cam timing?
SeVa-S13
Car: '05 GTO 6spd
R33's and up had VTC, hence the hump on the intake side of the front timing cover which the RB20's and R32 RB25DE's lack: it's the solenoid.
