VVL on 240sx
d3vilskid
Car: 240sx '95 coupe
Ok guys im just wondering here and would like to now if its possible to make a VVL for a 240sx, cuz if its possible i would like to do it or even try siince it seems like it really revovles around the camshafts havin extra lobes, n hydralic pressure wit da oil? It mite be a stupid question, but i would still like to noe. thank you
andyman61
Car: 1989 Nissan 240SX Hatchback
no, it's not possible unless you have $$$$$$$$$$$$$ and a group of engineers and machinists at your disposal. basically you're describing VTEC, which has more than one set of cam lobes for each valve and depending on your rpm and hydraulic oil pressure, a different lobe will engage the valve. not to mention that engines that have variable valve and/or lift are tuned different than motors without.
howstuffworks.com is your best friend, btw...
