Check out the post from SupreamS14, about two thirds of the way down: A Tuner's Guide to the QR25DE.There is a link to a very good, detailed article about this engine. Very good information. It makes mention of the CVTC system. As an aside, I read somewhere else that the low red line for this engine is due to the long stroke (vs. a small bore). According to this article, it has a low red line due to weak valve springs, and not the lengthy stroke. I'm of the opinion it's probably both. The long stroke in this engine greatly increases piston speed at higher RPM's, but then again, I'm no engineer.Sentientbydesign wrote:CVTC differs from VTECH in that it doesn't have a higher intake lobe.VTECH has a second cam profile once it kicks in which allows higher air intake through the intake valves.CVTC on the other hand adjusts the intake timing and possibly durration if I'm not mistaken.So there is no changing of the CVTC to improve things.
Go do a google for "How Vtech works" and then do one for "How Continuously Variable Valve Timing works" then you'll see the difference and you'll stop asking if there's a way to make CVTC kick in.marcello wrote:okay. im still not to sure what it means but does anything kick in like a vtech?
I know hondas don't have any torque stock, but a modded H22 or K20 would change your mind.marcello wrote:o for sure no torque. my friends gsr is really fast but doesnt feel that fast if that makes sense, because there is no torque. but in my brother inlaws vr6 jetta with tons of mods.....that has a ridiculous amount of torque and makes it feel super fast. by the way they raced and the gsr got his children eaten on the highway by the vr6. then he raced my buddie with a spec and got beat.
