EnthusiastMan wrote:I've always heard that it limits the power, hence why people put S13 sr's into S14's. Perhaps cost is the main issue though..
the high port head makes the s13 sr20 a bit more rev happy and the low port head with long runners, again, helps the s14 with its low end.
in the past, you did not have much option with cams if you had the s14 unless you ditched the VTC unit and got a cam pulley instead. But now, pretty much everyone makes cams of any duration that you would want that will work with VTC. So it is no longer an issue.
