twistedshadows »
https://forums.nicoclub.com/twistedshadows-u74233.html
Tue Oct 09, 2007 5:04 pm
{edit} the problem is i have a surge power loss w/e you want to call it at highway speeds it feels like the timing is being changed while i drive (i know the feeling from 240's that have had bad timing issues) i just changed the guides and tensioners thinking they might be the problemthanksjoe
i went out side and looked at the exhaust sprocket and the timing marks to the cam pin and exactly the same so i would be able to use a ga16de exhaust sprocket on the intake cam correct?would i run into any oil problems?can i just put a plug in the vtc solenoid hole or can i leave the solenoid in there?will removing the solenoid cause a check engine light?and looking at the vtc timing chart between 1,100 and 5,400 rpm (vtc on) the timing is at 8 degrees advance and above 5,400 (vtc off) its -12 degrees
how would i time at like 5 degrees advance just use the orginal marks or would i have to slip the timing a few links (haven't messed with timing on chains before) so 1 link would equal how many degrees timing?
thanks sorry if i seem anoying or anything just really want to get this car back on the road and like i said its just a daily driver so im not worried about performance so what ever you guys think timing wise if i go this route would give me the best drivablity is fine by me thanks againjoe
