autoworkz wrote:from what i read, it was more like 5 years, project was launched in 1984 and delivered in 89.
The Q45 project was launched in 1984 with the engine development taking 3 years as per the SAE paper #900651 submitted by Nissan on the VH45DE.
Some other tidbits:
- Included angle of the valves: 46 degrees.- Ratio of valve diameter to bore: 0.41.- Engine torque @ 800 rpm: ~ 240 ft. lbs.- Coil-on-plug capability: 37 kv @ 9000 rpms.- Engine block construction: Hypoeutectic silicon alum. w/ 7-10% silicon.- Crankshaft construction: Two-plane forged steel.- Crankshaft features: Fillet rolled journals, Radio frequency hardened.- Crankshaft journals width: Rod = 44.2 mm, Main = 26.5mm.- Low pressure cast-in iron cylinder liners: 3mm thickness.- Piston weight and height: 402 grams & 62.5mm.- Connecting rod construction: High-strength, micro-alloyed free-cut. - Intake runner diameter: Tapers from 46mm to 42mm.- Intake runner length: 420mm.
I understand everything except the description of the connecting rod construction. What do they mean by high-strength, micro-alloyed free-cut? From what I have read so far, the rods are supposed to be forged.
