tempestas »
https://forums.nicoclub.com/tempestas-u138409.html
Fri Jul 31, 2009 4:11 am
When VTC is on, it advances the intake cams, which makes more low end torque. Just imagine shifting the whole HP/TQ curve to the left. VTC is normally off. It's off at idle, most likely crusing as well. High load under 4,600rpm (you step on the gas) it kicks in and creates better low end torque. At 4,600 it shuts back off to allow the high RPM power.
I would think of it as more.... normal timing vs 20 deg advance for low end torque. NOT normal vs 20 deg retarded for high end HP.
So if they were truely set 20 deg retarded, it just changes intended purpose, from adding low end torque when on - to now it needs to be on for normal use and off for high end power... only problem is 20 degrees is alot. Most people play with 3-5 degrees retard. 10 would be a whole lot. 20 degrees, while in theory retarded should make more top end HP.... it may be too much and just cause problems. You have no valve overlap at all. Something like the intake vavles are not opening until 10+ degrees AFTER the exhaust valves close. Thats bad.
I'd rethink the spec. If anything.... 5 deg retard for install.... or try stock first and go from there. And even 5 degree retard may be too much... if you arn't retarding the exhaust cams as well.
