VSS Wiring for RB25 S14
FinkenS14
Car: 1995 Nissan 240sx S14
OK guys like I said Im doing my own harness.
Ive converted my RB25 upper harness, but have disassembled the lower harness completely, so that the only thing left is the knock sensor harness, because I was told I can use the KA lower harness for:
VSSAlternatorStarteretc
My question is if Im doing that, how does the VSS get the signal to the dash? Does it go through the fuse box or something?
On my car right now (ka is still fully in the car), it looks like the lower harness connects to the upper harness VIA a big plug. Is that how the car is getting the VSS signal right now? How will it get that signal with the RB in the car?
Thanks guys.
And yes Ive searched many forums, and wiring diagrams and have come up with nothing.
Modified by FinkenS14 at 7:03 PM 7/8/2009
Bluefire
VSS goes to the fusebox, then to dash. I would look at the fsm, it explaines everything...
FinkenS14
Got a link with page # in the FSM.
So whats the plug going that looks like it connects to the upper harness right now?
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
haha you're working on this too late at night
The benefit of using the KA lower harness is to use the plugs that plug into their female receptacles next to the fuse box. All you need to do is figure out which wire on the KA harness is for the VSS and solder the RB VSS signal wire to that. Google the 240sx FSM, it is an invaluable tool.
FinkenS14
Figure out what wire it is? Thats easy its the ones that connect right to the KA VSS right?
Darius
Yes it is just that simple.
HxC_Nismo
Car: '98 Nissan 240SX SE R33 RB26DET
'07 Nissan Titan SE
'05 Toyota Corolla
i have the pdf file for the write up on the rb lower harness prep into s14 let me know if you want it
FinkenS14
I got that one. Found it and all the other swap stuff that came in handy on rbforums.org
