VSS Pulses per mile?
stuartlowery
On a 96 Model 240sx how many pulses per mile does the Vehicle Speed Sensor send out? This is criticle information for my dash swap.
Thank you
stuartlowery
Wow no one knows?
Any one with a service manual should have this information.Here's a tip on most GM cars it's 4,000 pulses per mile. What does Nissan use?
IvoryJ30t
Car: 95 Maxima GLE, 95 Maxima GXE
i think its 2000, but let me double check
IvoryJ30t
2000 pulse per mile 12v square wave.
IvoryJ30t
also, gm cars use an ac sine wave at 4000 ppm, but nissans use a 2000 ppm dc square wave.
stuartlowery
Gm uses a square wave thus Pulses per mile
A pulse is just a high low state.
Thanks for the info. I may be able to trick this into working correctly.
IvoryJ30t
it has to do with the pick ups. the gm cars with 4k ppm sensors use a hall effect sensor and a reluctor ring, whereas nissan cars use a geared sensor with im assuming an optical interruptor to create a square wave.
IvoryJ30t
i make my own pc boards and the like, i know about electronic components.
IvoryJ30t
gm cars that use the 4k ppm sender usually use a hall effect sensor. the square wave senders are usually 2k ppm. and then theres the 40 and 17 pulse per driveshaft revolution units...
stuartlowery
Please correct me If I'm wrong but I'm feeding a signal of 60HZ into the nissan speedo I should recieved 108MPH if the speedo runs directly from a 2,000 Pulse/ Mile Signal. I'm not getting that instead I'm getting 27MPH which would meant the speedo is tracking off of a 8,000 Pulse/ Mile signal.
Here's the math
((Hz*60)*60)/MPH=Pulse per minute.
60hz = cycles per second
So if I take 60hz and convert that to minutes that would be
60*60=3600 And convert that to hours would be
3600*60=216000 Now let's take the displayed MPH and devide that by our cycles per hour to get cycles (pulses) per Mile. So that will be...
216000/27MPH = 8000 P/M
Any math majors able to confirm that?
Sanjuro
euh, I had the wrong info here for the longest time. see my writeup here
http://wp.me/pBmJh-2x
