onosqv »
https://forums.nicoclub.com/onosqv-u507.html
Tue Dec 27, 2005 2:29 pm
Searching will probably be your best friend, since no one person has gone through all the suspension and able to tell you exactly what will be the best bang for your buck.
A solid and easy to do combo is the kyb agx + rsr spring combo - very stiff but still "comfortable". Or kyb agx + sportlines, tein springs, etc. There's also a few other options such as koni yellows + ground control springs, etc - you can usually find reviews for that floating around on this board somewhere.
If you can stand coilovers (much more stiff and doesn't like too many uneven roads), I'd look into Megan Racing Coilovers, which are just a tad more than springs/struts.
If you save up more money, you can get KTS coilovers, lots of ppl love them including myself, from splparts.com.
Do that, suspension arms (depending on how low you go and how much you have) and tires and you should be good for a while.
