JeromeS13 »
https://forums.nicoclub.com/jeromes13-u227.html
Tue Aug 01, 2006 10:26 pm
40psi seems a bit high. What size tires were you running? IIRC, when I was running 215/35/18 or 225/40/18, Yokohama had recommended 35psi all around. As far as the vibration, it sounds very typical of tire balancing. They may be "balanced" or whatnot. But, I'm willing to bet money that its in the wheels/tires. And, if you're noticing it more in the steering wheel, its in the fronts.
