VR38VETT in new GT-R
A forum for owners and fans of the legendary Nissan Skyline and Nissan GTR.
audtatious
Just released via 7tune:
Japan’s Holiday Auto magazine goes on the record confirming the name and specification of the upcoming GT-R’s engine in its latest ‘GT-R Perfect Manual’ edition.
Even though the 2008 GT-R’s release is still just under two months away, Holiday Auto has been hard at work putting together a 10 page article exploring the new GT-R’s engine, chassis, driveline and interior features, some of which is old news by now but included nonetheless. We’re told that Nissan was in fact looking at a V8 engine to use in the GT-R in its early stages of development but found that the VK45 from the Nissan President wasn’t an engine worthy of the ‘R’ in the GT-R’s badge. Although it could satisfy the power, torque and driveability deemed necessary for the GT-R, the way in which it delivered those attributes was more befitting of a large saloon than a GT car. There was also a status problem, the VK45 being associated with Nissan’s luxury sedan would cause problems with potential GT-R buyers who were looking for more exclusivity… well exclusivity is what they got.
The VR38VETT
Holiday Auto broke the news about the existence of a VR based GT-R engine last month, and since then has gone one further and given us a actual alphanumeric designation: VR38VETT. The VR38 is actually a recreation of the famed VRH35L V8 powering the R390 Le Mans car albeit in V6 form. A lot of knowledge gained from Group C and endurance racing has allowed Nissan to take the performance aspect of the GT-R that little bit further (over say, a VQ based engine) by taking the basic design of the VR38 and using it for the new GT-R’s V6 engine block and cylinder heads. A surprising feature of the twin turbo system is the ‘Integrated Exhaust Manifold Turbine’ where the exhaust manifold and turbo exhaust housing are formed as one piece. We’re told this is for weight saving, packaging and high response and was chosen over the more costly ‘motor assisted twin turbo system’ that was predicted way back in mid-2004. What all this has resulted in is an engine design that could be viewed as two 1.9L straight 3-cylinder DOHC turbo engines joined by a common crankshaft, with separate intake manifolds and throttle bodies for each bank. The intake manifold is actually the centerpiece of the engine bay, its intake runners being used as a design feature of the VR38VETT as shown in the CG mock up image shown below.
Cosworth’s involvement in the GT-R’s engine development has been mentioned before on many occasions but until now there hasn’t been much information on what they’ve actually done. Holiday Auto tells us the GT-R’s aluminum engine block is a ‘monoblock’ design, meaning it doesn’t use sleeves inside each cylinder bore so that the pistons make direct contact with the block. Cosworth has also reduced the weight of the crankshaft, conrods and pistons to achieve maximum response and a free revving nature that belies its larger 3.8L capacity. It comes as a surprise too that the whole engine looks a lot shorter than what you would expect a 3.8L engine to be, its compact design and light weight being a major contributing factor in the cars overall balance. Many other parts such as the cam covers, timing chain cover, oil pan and a multitude of bolts, screws and washers are all made of magnesium. The GT-R will also use a semi-wet sump system which can handle higher g-forces over a traditional wet sump which start to suffer from ‘oil sloshing’ at around 1.8g. As pointed out in our previous article, the power delivery of the VR38VETT is extremely linear and does not drop off after hitting maximum power at 6,800rpm which was a big factor in proceeding with the development of an all new engine. From as little as 1,500rpm a powerful surge can be felt with - what seems like - all 480ps available with very little throttle application. It has been said that there are very few people with enough skill to drive the new GT-R at its limit, this limit being so high that a driver of average skill level would never be able to test the boundaries of the GT-R’s performance… this could possibly be an exaggeration on Holiday Auto’s part, but the point has been made clear: the new GT-R is every bit a Supercar.
Encryptshun
Car: 2005 Nissan Xterra
Integrated Exhaust ManiHOLD Turbine?
Wait....what?
Andy_V35Sky_350GT
Car: 2003 Nissan Skyline 350GT
Thats one heavy mo fo of a coupe.
0-100 3.9secs
audtatious
Just think what it would be able to do with some weight reduction and additional motor mods
Unstroked
Imagine what a simple mbc can do for this beast!!!
Gold Digger
Car: Current:
2011 Infiniti G25X
Former:
1995 Nissan Skyline GT-R V-Spec Midnight Purple
1990 Nissan Laurel Club S Turbo Two Tone Pearl
Encryptshun wrote:Integrated Exhaust ManiHOLD Turbine?
Wait....what?
Common, Chad, do you need to brush up on your Engrish? Japanese people can't say words with an F in them....lol
audtatious
That picture is computer generated so the person who did it obviously can't spell......Or it's as Neal stated above
Encryptshun
C33LaurelRacer wrote:Common, Chad, do you need to brush up on your Engrish? Japanese people can't say words with an F in them....lol
That why I say "Huck you, Joe Boo!"
I solly, I solly!
Gold Digger
Car: Current:
2011 Infiniti G25X
Former:
Yeah, that is not what the engine bay will look like. Lemme go get a magazine I had while in the hospital. It's got some shots of it. Give me about 10 minutes or so.
Gold Digger
Car: Current:
2011 Infiniti G25X
Former:
As promised....these were taken from a magazine, so bear with me.
Front cover
Main page of article
Story and specs page
Final page of article and a lead in to the new Fairlady
Interior (still masked on some parts, as you can see)
Engine bay. Note the V-VEL 3.8 Badge above the GT-R badge
Tire, wheel and brake; front driver's sideTire and wheel specs: F/ 255/40/R20 with 6 pot caliper and drilled rotors.R/ 285/35/R20 with 4 pot caliper and drilled rotors.
Close up of rear passenger shot.
And, this was a gift from a friend of mine while I was in the hospital this past weekend.
Encryptshun
Gah! Autotragic!!!
Or, even worse....CVT??
audtatious
Maybe they were just testing the VQ38 since that has since been released in limited production as a 380RS in Japan.
Andy_V35Sky_350GT
Hey dude, can you please scan the 370GT article that it mentions in the bottom right hand corner.
Would love to see it.
Thanks!
duffman1278
Car: 89 240sx Hatch, the wildcats!
OMG that engine is going to be insanly quick and very light for its size. I can't even imagine how much that engine will be able to take just stock alone but probably ALOT.
Coolwhip
Vendor
Car: RB26 Raw Brokerage War Machine
ohh how i love it
Death By Thrash Metal
Car: Well, i am a liar so it doesnt matter
wow... that car will be getting the best reviews in the world i bet. If it lives up to all the stuff weve been hearing then it will be worth the wait and whatever whopping pricetag they through at us.So no vq? dam. well they might have som similaritys so u can deck out your 350z with...but that car is just godly. Period.
clutchgordon86
i just wish this thing wasn't going to be so expensive.
and hopefully sales stay alright and they keep them in the states.
s86d
Car: autocross, backroad racing, and working on 240's
$68,000
holy crap
keith0486
hmm i wonder if that engine will fit in a s13 or s14
x240xdrifter
Car: 1991 Nissan 240sx
hell to the ya!
m tr4nch
Car: RS13, Z31, P11
i must admit i didnt like how the new gtr looked at first, but DAMN that looks sooo sweet to me now.. definitely grew on me
i sense more engrish....
Return to “GTR Forum / Skyline Forum”
