ahhsk wrote:Hello im new and this isnt flame bait.
an entire car (infinty Q45 92 vintage), not a clip, can be had for the same prices an sr20det can be bought for.
Or you could just keep the car and get it back into proper condition and then maybe mod it.
Of course many Q's out there need to have a lot of maintenacne done to them after purchase.
Since Q maintenace is so expensive it often makes the problem worse as the previous owner is less likely to have done proper upkeep.
To get the average used Q back close to "as new" handling + performance+safety runs between $3000-8000.
This would typically include new rear subframe assembly (1.-1.5k, front end rehab 2k, brake work 0.5 to 2k depending on condition,guides to cam chains best price in US 1.2-1.5k,new shox/springs, new bushings alla roundThe above are the must have's for almost all used Q's;you may also need injectors 1.2k, ox sensors, knock sensors if previous overheat at this age, transmission 3k.
While this may sound like a lot that is policing up things that most PPL dont properkly maintain in an older car.
Its actually a lot cheaper to maintain or bring back to nearly "as new" an older Q than a BMW 7 series or equivalent V8 MB.
Fred...
