DaveVQ »
https://forums.nicoclub.com/davevq-u100582.html
Mon May 04, 2009 8:08 pm
Quote »Off the top of my head you will need...
Fabricate new front suspension, the current one will not work for a RWD car.Fabricate a subframe to mount the engine to, as well as support the new front suspensionSteering, You will also need to fabricate a new steering rack, as the current position will prevent any rwd engine setup from being installedProvide enough clearance to mount the new engineFind some way to route the exhaust, since the exhaust tunnel will be filled with a driveshaftFabricate a new rear suspensionFabricate a rear subframe to hold and support a rear differentialHave custom axle shafts made, unless you can find a diff/axle/hub setup that will fit correctly under the rear of the max, and work with your custom suspensionChassis bracing - The maxima was not designed to handle the torque on the rear of the chassis, you will need to brace as required to prevent the rear from tearing itself apartNew driveshaft - You will have to determine the proper length and pinion angle, you will need to have the rear diff or axle housing offset properly, as well as the engine, otherwise your driveshaft will vibrate and/or tear itself out or the U-joints will fail prematurely. Driveshaft will have to be custom made.Wiring, must find a way to integrate the V8 wiring into the car, your also going to have to find a way of reading a new speedo and tach signalTransmission - You will need to find a transmission that will fit in the tunnel space, which was never designed to hold a transmission. You will also need to align everything so that the shifter will come out at the proper point, unless you plan on going automatic, which will be an even larger transmission, along with additional wiring. You will also need to find a way of supporting the rear of the transmission, as nothing under the car is provided, other than the thin sheetmetal of the floor.[/quote]From someone much wiser then I.
