I'm doing research for my internal combustion engines class and need to find out the following information about the VQ35HR engine:
Engine Designa) Key Specifications and construction(weight) -- MOST important! Need to know weight of engine.b) Intake and Exhaust manifoldsc) Valves/valve gear/camshaftd) Cylinders/cylinder Head/combustion chambere) Piston/piston rings/connecting rodsf) Camshaft/bearingsg) Cooling system(water pump)h) Lubrication System(oil Pump)i) Supercharge and turbochargej) Engine Block/crankcasek) Flywheell) Ignition Systemm) Fuel System
Please point me in the direction of helpful sites or other sources. Thanks
