VQ35DE Valve Covers - Paint Job DIY
Nissan 350z / Nissan 370z general community discussion forum
tollboothwilley
Car: 2003 G35 Sedan w/ NAV
So I have a (almost) new set of valve covers that I'm installing due to the leaking oil in cylinders #3 and #6. Along with the covers I have a set of new ignition coils I'm installing. However, before I do the install I thought that this would be a good chance to dress up the engine bay a little.
What better time to paint the valve covers right?
I decided that I was going to paint the covers blue because my catch can, jwt pop charger, and stillen engine damper were all blue and in the engine bay already.
Here's a pic with all the necessary goodies for accomplishing the job.
I used the simple green to clean the valve covers first. Spray and let stand for 5 min or so. I sprayed both sides of the covers. After that, wash off the VC's. Repeat process but this time use a tooth brush to agitate and clean any tougher areas. Follow with a thorough rinse. Let air dry for a few minutes then use a cloth (microfiber is best) to dry and prep the side we are going to paint.
This is what mine looked like after I dried them off.
At this point if you have a lot of irregularities you can sand/wetsand the VC's down. I was fine with the current condition of mine, otherwise I would have used 320/400 grit.
Next Step is to finish preparing the VC's for the adhesive promoter (primer) and paint. Tape up all areas. You can also tape any designs if you feel so inclined. Here's what mine looked like. In the pic you'll see I missed one spot on the right side VC. I taped that up later.
Spray 3 coats of the adhesive promoter on, allow 2-3 min between coats. This dries fairly fast. Be sure to get hard to reach areas as well. The adhesive promoter I used was clear so no need for a picture.
Start painting within 10 min of the last coat of primer. Here is mine after 2 coats of the paint I chose. (I chose this paint because it will withstand 500* temperatures)
I applied 3 coats of paint to my VC's. Here is what they look like. I brought them inside to dry. It still gets cold in the garage overnight right now. This will ensure that the paint is ready for the clear coat (It needs 3 good drying hours).
Clear Coat. Did 3 coats of it here. Brought it back inside to finish drying completely.
Removed all the taped areas. Finished look, ready for install.
INSTALL
To start with...
Remove upper and lower plenums
Heres the stock valve covers
Removed the drivers side, now you can see what's inside!
Before installing, you need to use RTV here.
Drivers side in, side by side comparison.
Both installed now.
With plenum back on.
NOTE: This is not my final product. I have plans with the Plenum. Should be polished up and on soon.
Modified by tollboothwilley at 9:51 PM 3/3/2009
R350Zz33
Car: 2008 350z enthusiast
looks good ive been thinking bout painting some of the components in my engine bay
aris_unlimited
Car: 1998 Ford F150 4.6L 5 speed. Edge programmer, 2" lift, 35" tires.
R350Zz33 wrote:looks good ive been thinking bout painting some of the components in my engine bay
save money, buy tires
bmike818
Car: 2007 Z
I can't wait to see the Valve Covers installed. I can really
dasoupdude
Car: 2005 Nissan 350Z
E
Engine/battery/fluid covers YAYYYYYY
tollboothwilley
I just might do the battery/brake fluid covers as well.
We'll see.
R350Zz33
if u want blue ones my friend that just got a used 04 has blue ones
xjmxstac
Car: 2003 nissan 350z track edition
^^^He already painted it blue, why in hell would he want to buy another set of USED blue ones? Why, huh, why?...
BTW OP, nice job, please post finished product installed!
Anthonysflying
Car: 2004 Silverstone 350z Touring
this is kind of off topic but are you replacing the coils with OE or did you find something anything quality?
tollboothwilley
Replacing with OE
I bought a set of them for cheap. Normally like $80-90 for one.
My car has 135K right now.
tollboothwilley
updated.
AZFAIRLADYZ
Car: 2008 nissan 350z/ VQ35HR
wow nice! I'm wondering what its going to look like when its installed
tollboothwilley
This is very inexpensive compared to tires/wheels.
Just takes some time and patience.
bmike818
Car: 2007 Z
off topic
zer...front
tollboothwilley
FYI - Install finished
This is not the finish look of my engine bay, just the finished look of the valve covers.
BusyBadger
Car: '92 Nissan 240SX
'05 Nissan 350Z
'13 Nissan Juke
xjmxstac wrote:^^^He already painted it blue, why in hell would he want to buy another set of USED blue ones? Why, huh, why?...
tollboothwilley wrote:I just might do the battery/brake fluid covers as well. We'll see.
Richie was talking about the unpainted covers that were referenced above.
Now, less nitpicking and more work on cars.
OP - Are you doing your own polishing on the plenum or outsourcing it?
tollboothwilley
Doing it myself.
Been working on it for a while.
I have some Tripoli and some Rough but its been cold here lately so its not warming the aluminum up enough to polish properly.
Its a PITA for the polishing. I didnt realize how long it takes.
Anthonysflying
What kind of equipment are you using to polish? the plenum starts out pretty rough right? maybe a sandblast would help start things off. I would rather polish the inside
Logan76
Car: Junk
I dont know if sandblasting it would help at all, It would just turn it white. If you do have any abrasive blasting done, make sure you glass bead it, it will come to a nicer finish, because glass bead polish's but sand is abraisive.
NSRsheets
Car: 2009 Nismo 370Z #85,1993 Nissan 240sx RB25DET coupe, 2013 focus
Did you replace the gaskets to? I just replaced mine because mine were leaking to. You got me beat on the mileage. I only have 110k on my 03.
tollboothwilley
I started it out with a really rough sand.
If I were to do it again, I would have it glass beaded.
I replaced the gaskets as well when I replaced the VCs...and ignition coils.
Feel a def. change with the new coils. Pulls much harder from 3000K up.
Return to “350z / 370z Discussion”
