VQ35DE-Timing Belt or Chain?
Discuss topics related to the VQ series engine.
ntwrkd
I have a friend that has a 2004 Pathfinder with the VQ35. Anyone know if it has a timing belt or do they use a chain?
93HATCH240
Car: 1993 NISSAN 240SX HATCH
chain
toddnos
Car: 2003 infiniti g35 sedan
when should the chain be replaced...100xxx miles?
93HATCH240
the chain should never have to be replaced unless your either rebuilding the motor or if its loose which means new timing set
toddnos
93HATCH240 wrote:the chain should never have to be replaced unless your either rebuilding the motor or if its loose which means new timing set
cool..thanks for the reply..
SHIFTVAX
Car: 2006 Nissan Altima SE-R/92 N issan 240 SX
Nissan only uses timing chains now, been that way for at least a decade.
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
SHIFTVAX wrote:Nissan only uses timing chains now, been that way for at least a decade.
Actually, only 4 years. The Frontier and Pathfinder used the belt-timed VG33E until 2004 and 2003 respectively. Quest used it until 2002.
SHIFTVAX
My fault then, I thought Nissan did away with them in the early 90's guess not.
Adnan
Car: 2001 Pathfinder LE 4WD
agreed with the minister
Return to “VQ30DE / VQ35DE / VQ35HR Forum”
