vq35de in an s14
98koukile
Car: 1998 Nissan 240SX LE
I know this topic has been gone over but they've all been frankenstein drivetrains. If I buy a totaled 350z or g35 would I have all the part necessary for the swap minus the driveshaft and mounts and a few custom fab parts? I would use the stock ECU so I know I would need the ignition and could utilize the VTC and drive by wire. Also could the steering rack be adjusted to work around the header therefore allowing the motor to be mounted lower? Did a lot of research about the swap including reading all of Fred's pages but I haven't seen all the parts out of a RWD in the same car yet. I know I know but I couldn't find this answer anywhere. Also I looked at the sr swap and the rb swap so I don't need to know about those at all. Mass is almost as bad as Cali and I'd rather just put a USDM motor in and worry about turbo later. Bring on the
